TFS Connection Question
ashirket
Post by ashirket »
I am currently testing InstallAware X9 with the TFS integration feature. I am able to connect to the server fine using the VS integration but for some reason I am unable to select anything other than the default collection. There is no dropdown, like you would see in Visual Studio, that would allow me to select a specific team project.
Is there something special that needs to be done in order to select a specific team project?
Re: TFS Connection Question
Did you select the correct "TFS Engine Version" from Installaware Options?
https://www.installaware.com/mh5/deskto ... arance.htm
https://www.installaware.com/mh5/deskto ... erview.htm
ashirket
Post by ashirket »
Interestingly it doesn't show the TFS version we have, which is 2013. The earliest version I can select is 2015/VSTS. Is there a setting during the installation that needs to be enabled to show the older TFS versions?
Really strange.
Which is your IA version?
Opss ...I didn't see you are using X9.
At any rate, there is nothing special that needs to be selected during product install.
This is from X11, in X9 (I don't recall excatly) you may have just the "Team Foundation Server integration" node.
