Hi everybody,
I'm getting trouble running Installaware installers (created with X2 or X7 versions) in Windows Server 2019.
The problem is when the installer tries to download something (using Download File command, o also with web media blocks), it fails. If I try to download the same url from a web browser (or from other tools like Powershell, for example), it work ok.
I'm logged with a user in the Administrator group.
Have anybody faced somethink like this ? Any help would be greatly appreciated.
Thank you,
Alejandro
Problem with downloads in Windows Server 2019
AleBlengio
Re: Problem with downloads in Windows Server 2019
Make sure you have a MIME Type setup for .7zip. I ran into that quite awhile back on an old 2003 Server and just adding the MIME Type corrected the issue. You might also look into your timeout settings.
