I'm trying the demo for Express x9
Under User Interface \ Shortcuts, I'm setting the option to "Run as Administrator" for the Desktop and Menu shortcuts, but it's not being set. I also tried checking the option in Application Requirements for "Administrator Privileges" and still nothing.
Also, after a build and running the install the check box for "Run Now" is set but the program doesn't run after the install (unless you run it manually that is).
Nothing fancy set, just the basic standard options. Any help is appreciated.
