install run times based in features?
shadow
Post by shadow »
is it possible to make a single setup with Installaware for both client and server installation?
Server version must install SQL server as application runtime, and program files(targetfolder) , and the client will install only native client (not SQL server ) and program files,
Features, as I understand, do not affect runtimes.
Is installaware capable of handling this situation?
shadow
Re: install run times based in features?
Post by shadow »
Is not this possible with Installaware?
I am trying to choose an Installer. Would you please help with this?
glenharvy
Post by glenharvy »
InstallAware say they don't monitor these boards as they charge for support. It is peer-to-peer and there aren't to many peers around. :cry:
You could ask Sales about these issues as they do respond if there is a sale in the wind :D
The short answer is Yes it can. Add the 'Feature' and then surround the code that loads the 'Feature' with an IF/Else statement.
shadow
Post by shadow »
Thanks for reply.
