Predefined Folders Listing
alphonseg
Post by alphonseg »
Where can I find a listing of paths for the Predefined folders for Windows 10 and 7?
pfennig
Re: Predefined Folders Listing
Post by pfennig »
Your question is a bit unprecise. For general purposes Wikipedia might help:
https://en.wikipedia.org/wiki/Special_f ... al_folders
alphonseg
Post by alphonseg »
Thanks for the reply. I will try to clarify.
In Setup Architecture > Files, files can be added to system folders. The system folders listed do not all, exactly match those from https://docs.microsoft.com/en-us/window ... -variables or even the Wikipedia link.
I also don't see on for Program Files(x86).
Where can a get a complete listing of the predefined folders used in InstallAware and what they map to in Windows 7 and Windows 10?
Right click on the "Target Folders" root node, then from the context menu select "Add System Folder...".
alphonseg
Post by alphonseg »
Thanks for the reply, however 2 months is a bit too late.
...but it may be still helpful for someone else. :D
