Uninstall previous version
aimcorp
Postby aimcorp » Fri Jan 31, 2020 5:32 pm
how I do uninstall a previous version or at least delete the old shortcut?
Looked in the help file, but can't find anything.
Thanks Ariel Maisonet
Re: Uninstall previous version
Postby FrancescoT » Mon Feb 03, 2020 7:12 am
Not sure to follow your question.
Previous version gets automatically uninstalled when you install a product update, and the same is true with shortcuts.
At any rate, during your product installation you may store somewhere on the target system, the value of the "UNINSTALLLINK" pre-defined variable.
UNINSTALLLINK: Initial value set to the full path of the uninstallation setup program.
https://www.installaware.com/forums/viewtopic.php?f=2&t=10736
https://www.installaware.com/forums/viewtopic.php?f=2&t=10419&p=39483
https://www.installaware.com/forums/viewtopic.php?f=2&t=6564&p=24965
Users browsing this forum: No registered users and 77 guests
