I'm using the latest version of IA11 as a registered user and I have a question about the license file
(in support files): I would like to be able to select the license file
which will be displayed depending on a variable value get as a
parameter of my setup.
Example 1: mysetup.exe PARAM=A
In this case, I would like to display the support file called licenseA.txt
Example 2: mysetup.exe PARAM=B
In this case, I would like to display the support file called licenseB.txt
Is it possible to do such a thing with IA11? If yes, can you help me
because I don't know how to do.
As an alternative if it is not possible to change the support file for
the license, is there a way to dynamically change the text of the
license?
Thank you for all of your answers.
Best regards,
Andre
Select license file depending on a variable
Re: Select license file depending on a variable
yes, you can ...but you have to use a custom approach for loading the text files conditionally, and then displaying the loaded txt content.
- You should add your txt files to SUPPORTDIR.
https://www.installaware.com/forums/viewtopic.php?f=2&t=10676
To conditionally load your txt file on the base of a variable value passed from command line, declare a script variable at the very beginning of your man script, and assign it to itself (this automatically assigns the CMD line parameter MY_CMD_PARAM to the script variable, ex: mysetup.exe MY_CMD_PARAM=A).
For example:
Finally to display the loaded content (TEXT_FILE_CONTENT), add a MEMO Control to your custom "EULA dialog", and enter $TEXT_FILE_CONTENT$ into the "LINE property (TMemoStrings)" of the control.
For example:
Set Variable MY_CMD_PARAM to $MY_CMD_PARAM$
Set Variable TEXT_FILE_CONTENT to
if Variable MY_CMD_PARAM Equals A
Read from Text File #READALL\$SUPPORTDIR$\licA.txt into Variable TEXT_FILE_CONTENT
(*) consult the product documentation for details on "Read from Text File" command.
Hi Francesco,
This is exactly what I would like to do.
Thank you very much for your help.
Best regards,
Andre
Best regards,
Andre
Users browsing this forum: Baidu [Spider] and 198 guests
