Variable in Product Name
andre
Postby andre » Fri Apr 10, 2020 1:45 am
I'm using the latest version of IA11 as a registered user and I have a question about the "product name" project property.
In fact, my setup is mandatory launched with a parameter and this parameter allows me to set the product name value, so in the "product name" property, I have something like :
Product Name: $MY_PRODUCTNAME$
The perfect thing is that when the wizard is displayed (and everywhere it is used), the product name is well replaced with the value of my variable, but I have a problem with the Control Panel of Windows: in the applications list, my application has not the name of my variable but the name of my application is $MY_PRODUCTNAME$ which is a problem for the users.
Do you think it would be possible to change the name in the applications list ?
Thank you for your answers.
Best regards,
Andre
Re: Variable in Product Name
Postby FrancescoT » Fri Apr 10, 2020 1:07 pm
You cannot set the Product Name at setup runtime. This must be assigned at Build Time.
You may eventually use a compiler variable to set the Product Name, but this can be done exclusively at BUILD time in any case.
https://www.installaware.com/forums/viewtopic.php?f=2&t=8927
andre
Postby andre » Wed Apr 15, 2020 2:44 am
Thank you for your answers (even if I was expecting something else :D).
Best regards,
Andre
Users browsing this forum: Baidu [Spider] and 194 guests
