Delete temporary compiler files
D MMacPherson
Post by D MMacPherson »
New user of InstallAware Express. Long-time (20 years) InstallShield user. One thing that I would like to do (and cannot see any settings for this) is to have IAX delete the multiple temporary compiler files in the project directory (i.e., all of the dll and dialog form files that are created dynamically but are not in today's date). Once I have an installation built, I do not need (nor want) to retain these files. Aside from manually deleting them, is there a setting that I am missing? Thanks!
Re: Delete temporary compiler files
Can you please clarify with an example which are those files?
The build process doesn't store any temporary file under the project directory.
The build process may store some extra files under the project directory...however, none of these are temporary files.
