Windows 10 as "Minimum operating system"?
anja_laenge
Post by anja_laenge »
Hello support,
using X9 (Build 2.8.2019) how can I set the minimum operating system to Windows10?
kind regards
Anja
Re: Windows 10 as "Minimum operating system"?
In your setup script, just use the "Get System Settings" command to check for Windows 10 capability.
The return variable will hold TRUE if the system meets the minimum capability.
anja_laenge
Hello Francesco,
I see. Thank you.
Kind regards
Anja
rev23dev
Post by rev23dev »
Why is this not in the Application Requirements tab's Minimum Operating System drop down? Why does that max out at 7?
It's quite complicated to discuss the reasons here. Unfortunately, there are several technical reasons.
We are aware of the problem...let's see what happens.
