Windows 7/8/10 but PRO as "Minimum operating system" ?
dcube
Postby dcube » Fri May 08, 2020 8:23 am
Hello Support,
I need to check and block installation if Windows (7,8, 8.1, or 10) is less then PRO editions or greater.
How to ?
Best regards
Paolo Botti
X11 Version
Re: Windows 7/8/10 but PRO as "Minimum operating system" ?
Postby FrancescoT » Fri May 08, 2020 2:01 pm
Unfortunately, it's not available a ready to use built-in method for detecting the target Windows Edition.
However, you may implement your own method (for example; with invoking a custom DLL or. EXE) around the "GetVersionEx" WINAPI. This function returns the target edition through the "OSVERSIONINFOEX" structure.
https://docs.microsoft.com/en-us/windows/win32/api/sysinfoapi/nf-sysinfoapi-getversionexw
dcube
Postby dcube » Sat May 09, 2020 3:45 am
Thanks Francesco for the answer,
I know the sysinfoapi functions in Kernel32 but honestly I would have hoped for another answer.
If we prepare our own DLL we will make it available to other users as well.
Best regards
Paolo Botti
Users browsing this forum: No registered users and 176 guests
