The Installer running as Admin still cannot access parts of Registry
ezG
Post by ezG »
Our company recently removed admin privileges from our laptops. When I'm logged in as myself (non-Admin) and run an install, a login dialog pops up requesting the credentials of an account with admin privileges.
My msi
[*]Looks for the "UninstallString" under HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall<App Name>
[*]Executes the command string retrieved in step 1.
[*]Continues with the Rest of the Installation
This worked fine before the security changes. Now when my MSI runs
[*]The Software listed in HKCU...\Uninstall is not removed because that registry path is invisible to me.
[*]The new software does not appear in Control Panel-Programs and Features
[*]The new software seems to function just fine; If not for the logs we wouldn't know that it installed without error.
Why would the Admin account I was given not be able to see the HKCU\SOFTWARE..\Uninstall key?
The command line we use is msiexec.exe /i company.msi /qn /lvx* C:\msirun.log
Should I be adding anything to this commandline?
Re: The Installer running as Admin still cannot access parts of Registry
If you are installing PER-MACHINE (ALLUSERS=TRUE), you must have full ADMIN rights to install the package. Alternatively, you must provide Admin credentials when the elevation prompt pops up.
ezG
Post by ezG »
It turned out to be a mistake.
It turns out that the service technician that was helping me used a different account with administrative access.
My msi looks for user installs under HKCU. It didn't find it because it was installed by a different user and therefore in another part of the registry. This is why I couldn't see it. I was logged in as myself and not as the technician that did the install.
MYSTERY SOLVED!
