Disable InstallAware X12 to automatically check for updates
mwilner
Postby mwilner » Thu Sep 17, 2020 3:18 pm
I installed IA X12 but didn't see the option to disable the setup from enabling the check for updates automatically the system or IA starts.
Where can I disable this check so that I don't get the popup every time the app is used or the PC is started.
I am using IA on a build PC that has no physical attendance to click ok each time the app tries to start and check for an update.
Best regards,
Manfred Wilner
Re: Disable InstallAware X12 to automatically check for updates
Postby FrancescoT » Fri Sep 18, 2020 12:00 pm
You may disable or re-enable automatic update checking at any time.
For what concerns IA X12 specifically and if you did a PER-MACHINE installation, from command line run:
C:\ProgramData\{E7D6987C-A0F4-4A2E-AF32-553D9838CF66}\myahew.exe /updatesetup
while if you did a PER-USER installation:
C:\Users\Francesco\AppData\Local\{E7D6987C-A0F4-4A2E-AF32-553D9838CF66}\myahew.exe /updatesetup
The above command will launch the "InstallAware X12 update wizard" in the System Tray. From there select the IA Icon, and then apply your settings.
mwilner
Postby mwilner » Fri Sep 18, 2020 12:41 pm
Thank you, Francesco.
Manfred Wilner
Users browsing this forum: No registered users and 171 guests
