$SFXPATH$ does not work properly in InstallAware X12
tamarrra
Post by tamarrra »
We're moving our software products from InstallShield and are now in search for new good setup building platform.
Recently I've installed InstallAware to play with.
In our scenario we need to check if there is a specific .txt file placed near the compressed setup file. As I understood from help, $SFXPATH$ variable should return path to the uncompressed setup file. But in my case it returns some temporary path (see screencap below)
My compression settings are following:
I have InstallAware X12 installed on some virtual server with Windows Server 2016
What am I doing wrong here? And what is the correct way to get the path to the compressed setup file during the installation?
Thank you.
Cheers,
Tamara
Re: $SFXPATH$ does not work properly in InstallAware X12
I don't see any problem with the SFXPATH pre-defined variable, honestly.
SFXPATH: If an uncompressed directory layout is used, this variable is empty. Otherwise set to the full path of the folder containing the self extracting executable which bootstrapped the installer.
In the above test, I executed the Compressed Installer from "This is my folder" (sub-folder) on my Desktop.
