Start Menu Group and Program Files path allowing illegal Windows characters
dileep.tiwari
Post by dileep.tiwari »
I am just doing some R&D and i found StartMenu and ProgramFIles path are allowing users to enter Illegal character for eg.
i dont want to allow user to put any illegal characters to either startmenu or in programfiles path.
if anybody enters illegal characters in startmenu or in programfiles path NEXT button should be disabled.(NEXT button only enables if all entered characters are legal)
it there any way to achieve this. does installaware provide this functionality.
Dileep
Re: Start Menu Group and Program Files path allowing illegal Windows characters
You may use the "Parse String" script command for that.
The command parses a string by a given pattern or position index and splits the result into two new strings.
Then you can use the returned strings to validate your path.
dileep.tiwari
Can i get any example sample if it is available.
No, there isn't a specific sample available.
...let me see if I still have one.
With the help of the "Match Regular Expression" script command, it's really a simple matter.
For example:
Set Variable MYPATH to c:\test my pa*th
Set Variable ILLEGAL_PATTERN to [?*"\|]
Set Variable RESULT to
Match string "$MYPATH$" to regular expression "$ILLEGAL_PATTERN$", return result in variable RESULT
if Variable RESULT Equals TRUE
MessageBox: Debug, Path contains not allowed characters!
~InstallAware Clipboard Data~
~End~
~{970D8624-46C3-4579-9292-228853ABC057}~
~MessageBox~
~{D5FA8B62-F4E2-4476-8FC6-99EE3647EA51}~
~Debug~
~Path contains not allowed characters!~
~0~
~1~
~If~
~{740837F9-D8BA-4690-ADA4-2695441DB1E2}~
~RESULT~
~0~
~TRUE~
~FALSE~
~Match Regular Expression~
~{4203C2CA-B8BF-4BB9-88B6-8EFE45528245}~
~RESULT~
~$ILLEGAL_PATTERN$~
~$MYPATH$~
~Comment~
~{F61E11DD-D883-4399-A697-DFB6A08B306F}~
~Set Variable~
~{F2C37E85-36A4-4452-8CBC-6537433FE355}~
~RESULT$MYAH$MYAH$FALSE~
~Set Variable~
~{F0BD3777-039C-4593-968E-1E93D5F8D226}~
~ILLEGAL_PATTERN$MYAH$MYAH$FALSE~
~Set Variable~
~{2C6F4A85-0C8D-4601-B58B-8A412E044B4A}~
~MYPATH$MYAH$MYAH$FALSE~
~c:\test my pa*th~
