InstallAware X12 trial problem with virustotal.com
tamarrra
Post by tamarrra »
We're now in process of testing InstallAware Studio Admin.
This is a great tool, but we faced one problem - when checking InstallAware generated setup through virustotal.com it reports two threats.
To be sure I created empty setup project, compiled compressed exe out of it and then checked this empty project in the virustotal - same situation.
Can you advise something maybe? Not much similar topics on this forum.
Thank you
Cheers,
Tamara
Re: InstallAware X12 trial problem with virustotal.com
Dear Tamara,
in all honesty, I'm not sure how reliable it's such "virustotal.com" service.
I just built a dummy exe application using Visual studio. I simply created a new C++ project from scratch, and then I compiled the project as it is. Finally, I submitted the compiled file for a scan ...and these are the results:
...so frankly, I don't think this may be considered a reliable result.
