building a SingeFile setup, the resulting output exe has the language property in the details of the file set to "english".
I need to change this. How can I set the correct language here?
kind regards
Anja
SingleFile: setup.exe properties
Re: SingleFile: setup.exe properties
This should be set in the Project Options (SHIFT+CTRL+F11).
anja_laenge
Hello Francesco,
no, this had no effect. The setting already was German, resetting it to english, saving, closing, reopening and building had the same result.
EDIT: Using ORCA I can see that the MSI extracted from the SingleFile build has the correct 1031 ProductLanguage code. Nevertheless the displayed language in the details tab of the setup.exe is not German.
How can I fix this?
How can I fix this?
- 01.png (12.03 KiB) Viewed 8356 times
Yes, I also found that it hasn't any effect on the properties of the generated exe.
At any rate, this should not have any impact on the package localization...am I missing something?
anja_laenge
The customer wants to see his companies language in the file properties.FrancescoT wrote: At any rate, this should not have any impact on the package localization...am I missing something?
I am very sorry for that,...I can only escalate the issue.
anja_laenge
Please do.FrancescoT wrote:I am very sorry for that,...I can only escalate the issue.
We are using X9, it would be nice to have a solution working in this version, to0 - like a post-build lscript to run or something like that.
kind regards
Anja
anja_laenge
Hi,FrancescoT wrote:I am very sorry for that,...I can only escalate the issue.
is there anything new?
kind regards
Anja
Unfortunately, there is no news yet.
