Hi all,
I have a case where my install will need to copy 2 files "*.dat" from the same folder where the setup.exe is being executed.
These files are not included in the setup.exe but I would like my setup.exe to look for these 2 files in the same folder and if found, then copy them to a specific folder as part of the installation.
If this possible? if so, can anybody provide a sample code of the script?
Thanks a lot!
Copying files from installation folder at runtime
Edhy Rijo
Re: Copying files from installation folder at runtime
You may use the "Copy/Move Local Files " command as below:
Here I used the SETUPPATH pre-defined variable to obtain "the outermost folder containing the executable program or setup database that initiated the installation".
(*) "Copy/Move Local Files" is a Windows Installer Command, by default its execution is deferred to "Apply Install" execution. To overcome such behavior, I used the IA NATIVE ENGINE to force an immediate execution of the command.
Copy Local Files $SETUPPATH$\MyFile.dat to c:\MyfolderSet Variable NATIVE_ENGINE to FALSE
~InstallAware Clipboard Data~
~Set Variable~
~{63F3FFF3-A60E-46D4-AA16-0D4BB4683398}~
~NATIVE_ENGINE$MYAH$MYAH$FALSE~
~FALSE~
~Copy/Move Local Files~
~{03F7929C-6C58-4078-A3A2-495676CD71BA}~
~$SETUPPATH$~
~MyFile.dat~
~c:\Myfolder~
~TRUE~
~FALSE|FALSE~
~Set Variable~
~{A7B1ACDD-5203-483E-8A59-8DD716EDCDA7}~
~TRUE~
Hi Francesco,
Thanks a lot, that will definitely get me started in the right direction.
Edhy Rijo
Users browsing this forum: No registered users and 120 guests
