I have a scenario where I have defined a variable suppose ABC. by default it has no value.
on the basis of the value of the variable, I have to control the checkboxes from the dialog box.
this is the code:
Set Variable INSTALLSIMTRANSWEB to
if Variable INSTALLSIMTRANSWEB Equals TRUE
Set Variable SIMTRANSWEBcb to TRUE
I have added the rules when SIMTRANSWEBcb is checked then another checkbox should be visible
after build I am running exe through the command line (no silent):
shopfloor.exe INSTALLSIMTRANSWEB=TRUE.
AM I DOING SOMETHING WRONG?
i want the checkbox should be visible when the INSTALLSIMTRANSWEB has value TRUE.
Change compiler variable value on installation through commandline
Re: Change compiler variable value on installation through commandline
This has nothing to do with Compiler Variables.
You only need to define a custom script variable for your purposes.
Example:
- at the very beginning of your main setup script, declare your variable and assign it to itself.
Then run your package as you are already doing:
That's it!
Example:
Set Variable INSTALLSIMTRANSWEB to $INSTALLSIMTRANSWEB$
Comment: ...Do something!
That's it!
Thank You, I got it working!!!!!!!!!
Happy you solved.
