Is it possible to check the current file system without writing a dll to check it? I need to check that the file system is NTFS, if it isn't I will terminate the install. I've looked in the help but can't see this mentioned anywhere.
Paul
Check file system
There isn't a built-in command that does this...if there is an API call in Windows that returns this information, you may call it directly using the Call DLL Function command.
Martin Rothschink
AxoNet Software GmbH
Users browsing this forum: No registered users and 49 guests
