The miae.exe of the release of Dec. 23rd is corrupt.
IA X13 - miae.exe corrupted
pfennig
Re: IA X13 - miae.exe corrupted
Same for me
miae.exe - Bad Image
...\InstallAware\InstallAware X13\mext.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0xc000012f.
OK
I've downloaded the single file installer twice. They were identical. Therefore I expect that it is not a transfer problem.
Only the Dez. 23rd build (30.01.00.2021) is affected.
best regards,
Stefan
OK
best regards,
Stefan
Coder For Food
Me too. If this is indeed a problem, I can not believe there has not been a response since originally reported, a few days ago.
I just downloaded (full download) from the x13 IA download page, successfully ran the installation, tried to execute from all newly created links, and the exe itself, and instead of successfully launching, getting this "maie.exe corrupt" message, just be for the app exits.
Am I missing something?
- Capture.JPG (13.32 KiB) Viewed 6814 times
Coder For Food
I just tried installing and running the web install version of IA13 and it installed and is successfully executing.
Please try with downloading once again the package, the issue should be fixed now.
Please accept our apologies.
Coder For Food
Francesco,
Thank you for the quick response and follow-up.
Currently, I have the smaller Web install x13 installed and successfully running on my production system so I do not want to mess with the install.
However, it sounds like you have identified and resolved the problem. The next time I do install, I will use the full runtime version and let you know.
Thanks again.
-Michael
Thanks again.
-Michael
Hi Francesco,
great, yes it works, after uninstalling and reinstalling. (Repair is not sufficient, obviously).
One wish I would have. Could you provide a MD5 Hash next to the download link, so that it is possible to verify the integrity of the download with e.g.
CertUtil -hashfile <path to file> MD5
Thank you very much in advance.
best regards,
Stefan
best regards,
Stefan
pfennig
Thank you, Francesco,
the new single file setup installed correctly.
Can you tell what happened?
A corruption during download seems unlikely. The setup file itself would have thrown an error message but it run through as it always does. Therefore I think even an md5 hadn't been useful in this case.
Nonetheless, I support Stefan's idea of providing an md5 with the download file.
