When I run :
Run Program $SQLSNY_RT$ As $SQLANY_RT$\setup.exe (wait, get result into variable RT_RET)
I get a return code of -11 when I run as User Only
When I run for All users it runs.
I checked the users/appdata/local/temp/mia1/fb0 I cannot enter into this folder when I run as only user,
but when all users is checked I can get into the folder.
I tried all 3 optons of Run UAC elevation and get the same errors in all combinations, when I run as Admin of
the EXE or normal as well.
Run program returns -11 for only user
Re: Run program returns -11 for only user
Can you please specify the exact parameters you specified with "Run Program"?
it seems you are using "Run Program AS" , but it looks you specified "Setup.exe" with the USER parameter.
ok, had a slight syntax error
First I :
set variable SQLANY_RT to
define file bag : "C:\Omega\Deploy\Test-1\sqlany8RT\*.*, include files recursively, get runtime location of files into variable SQLANY_RT
then its either:
Run Program $SQLANY_RT$\setup.exe (wait, get result into variable RT_RET)
OR I tried also
Run Program under UAC $SQLANY_RT$\setup.exe (wait, get result into variable RT_RET)
First I :
then its either:
OR I tried also
I just done a test using the following code in a blank setup project, and it works fine either when running as PER-MACHINE or PER-USER. For what concerns UAC Elevation, I leaved the default setting: "highestAvailable (Elevate Administrators Only)".
Consequently, I exclude that your issue may be caused by this code specifically. I suspect instead that there is something else in your project at the root of your issue.
Set Variable FILE_BAG_LOCATION to
Define File Bag : C:\Program Files (x86)\InstallAware X13\runtimes\vc1410_25017_x86\*.*, include files recursively, get runtime location of files into variable FILE_BAG_LOCATION
Set Variable RUN_PROGRAM_RESULT to
Run Program $FILE_BAG_LOCATION$\vc_redist.x86.exe /install /norestart /quiet (WAIT, get result into variable RUN_PROGRAM_RESULT)
MessageBox: Debug, RUN_PROGRAM_RESULT=$RUN_PROGRAM_RESULT$Code: Select all
~InstallAware Clipboard Data~
~MessageBox~
~{1853AAA7-D7F9-4BB3-B7E8-9FB20D0178E5}~
~Debug~
~RUN_PROGRAM_RESULT=$RUN_PROGRAM_RESULT$~
~0~
~1~
~Run Program~
~{780E483C-E01F-48E3-918A-38D6E0BB1301}~
~$FILE_BAG_LOCATION$\vc_redist.x86.exe~
~FALSE~
~/install /norestart /quiet~
~TRUE~
~RUN_PROGRAM_RESULT~
~Set Variable~
~{B5604220-1EFE-4D21-A491-EF20076D975E}~
~RUN_PROGRAM_RESULT$MYAH$MYAH$FALSE~
~Comment~
~{5F8A26CC-9BD7-4F77-8D3D-D451BB876D6D}~
~File Bag~
~{FAA35565-5111-4E57-9308-14F8051A4958}~
~"C:\Program Files (x86)\InstallAware X13\runtimes\vc1410_25017_x86\*.*|",TRUE,FILE_BAG_LOCATION~
~mFileBagIDE.dll\mFileBagEXE.dll~
~Set Variable~
~{9030CB23-FAF8-40F0-AA14-724F210A561E}~
~FILE_BAG_LOCATION$MYAH$MYAH$FALSE~
The issue arises when I choose to install for This user only on the machine,
When I choose All Users the file location is accessible.
But from what I can tell selecting that option only changes the shortcut folder locations and does not
touch the MIIA1 temp file location which should be handled by the core
As I said I tried both install modes, as PER-USER (ALLUSERS=FALSE) and PER-MACHINE (ALLUSERS=TRUE). Both worked.
