Specific, machine suddenly returning "Fatal error during installation" during Install/Remove MSI Package?
Coder For Food
Post by Coder For Food »
My platform: IAx13/Win 10 H202
On one dev machine, I am suddenly getting the error, 1603/"Fatal error during installation" on one dev machine, when calling: Install/Remove MSI Package $PRODUCTCODE$[REMOVE=ALL] (get result into variable REMOVEOLD) to remove my previous installation or trying to remove through the OS add/remove programs.
Inside the log file ( attached), I see the following error messages:
MSI (s) (AC:00) [09:16:47:862]: Note: 1: 1725
MSI (s) (AC:00) [09:16:47:862]: Note: 1: 2205 2: 3: Error
MSI (s) (AC:00) [09:16:47:862]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1725
MSI (s) (AC:00) [09:16:47:862]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (AC:00) [09:16:47:862]: Product: MyoVision Software -- Removal failed.
MainEngineThread is returning 1603
Again, it seems to be something with this machine specifically that has changed as previously, it worked just fine.
What I have tried:
1) Manually removing the installation in the registry and reinstalling, and then uninstalling as above. Same result.
2) Removing the %TEMP% files. Same error condition.
Any ideas what to try next?
my_log.txt
(260.58 KiB) Downloaded 860 times
Re: Specific, machine suddenly returning "Fatal error during installation" during Install/Remove MSI Package?
Please have a look at the following threads.
viewtopic.php?f=2&t=11283&hilit=1603
viewtopic.php?f=2&t=10980&hilit=1603
Coder For Food
Thanks for the quick response. Unfortunately, while your two links touch on the issue I am having, they do not specifically apply to my situation.
In my case, my installation is always set to All Users. Further, prior to just recently, it worked fine on my dev machine and, it has always worked on other machines. That is why I feel it is something that changed, or hung around, during my debugging install/uninstall of my installations.
Any further suggestions? Does the log file help?
Most of the case (if not all), error code 1603 indicates that a file or a component is being held in use by another process. Due of this, I suggest you to verify if your installer is trying to install/uninstall "something" which seems to be currently in use.
Unfortunately often in such cases, the Windows Installer log doesn't indicate which component is causing the issue.
Coder For Food
Hi Francesco
OK. Your narrowing the variables down to the most likely root cause being a component sharing issue gives me a place to start.
Have a good weekend.
Michael
