Selected text color in destination screen
ngurram
Post by ngurram »
I've customized the install screens a little bit to have dark theme across. However in the destination screen the selected folder by default loads up black (screenshot attached). It changes color when focus is set in the browse window, but if you tab out of the box, the selected text changes back to black. How do I make it so the selected text / folder in the box stays highlighted even when I tab out of it?
Thanks in advance.
Re: Selected text color in destination screen
I'm not sure to follow your question.
At any rate, if you are referring to the highlight status of the currently selected foder (tree control item), this works as by design with a standard tree control.
The control keeps the highlight status of the item, but it fades to 'GRAY' when this loses the focus. However in your case, this doesn't look vsible due the black background of the ShellTree control.
ngurram
Post by ngurram »
Thanks Francesco. Is there a way for me to override the highlight color? If it's grey it won't be visible as in the screenshot. What can I do to keep it visible even when focus is gone from the tree control to Next button.
Unfortunately, it's not possible to override the highlight color.
I may suggest you to use a standard white background color with the tree control.
Btw, this custom VISTA BLACK Theme does exactly this.
viewtopic.php?f=5&t=1841#p7390
