Conditionally install files
Sheri_Steeves
Post by Sheri_Steeves »
I have versioned install projects that all use the same underlying mia script.
I want to include/install a collection of files only if a version number (it could be any variable, really) is greater than a set value.
Can I do this? Right now it throws an error that the older project version cannot find the files.
Re: Conditionally install files
Can you share some more details on how you have implemented this currently?
Sheri_Steeves
I have created a single underlying .mia script used by each versioned project. I need to be able to continue building a "release" version along with a "development" version and was trying to reduce the number of files and editing I needed to do. As well, the mia script is used by three projects as "flavors" of builds.
The latest version needs a subfolder of files that the older version does not have, so I tried conditionally including it as follows:
    if Variable INSTALLTREEVERSION not Equals 12.0.000
      Install Files c:\ss\work5\vector5\installs\#installtree_product#\installtree\#installtree_version#\comsamples\*.* to $TARGETDIR$\COMSamples, include subfolders
      Install Files c:\ss\work5\vector5\installs\#installtree_product#\installtree\#installtree_version#\runcommands\*.* to $TARGETDIR$\RunCommands, include subfolders
Trying to build this gives this error:
Error during build: No files matching pattern "c:\ss\work5\vector5\installs\TIFF Image Printer 12.0\installtree\12.0.000\comsamples\*.*"
I've set the variable INSTALLTREEVERSION to be ny compiler variable (set per project) and it is 12.0.000.
Is there a better way or a different way I need to handle this requirement?
Dear Sheri,
you are using a Custom Script Variable, and NOT a Custom Compiler Variable ...this is why you are having such problem.
Sheri_Steeves
Franscesco,
Aha! That was what I was missing. I'll keep that knowledge for future use.
I had to get the new build version ready for testing yesterday. I worked around it by copying the underlying .mia file and changing the script file set for each project in the MSICode tab.
I only need to do that when my install file collection changes which should be a rare occurrence now. It is one more file to maintain but not having conditionals for each version in a single file makes it easier to read.
