I'm using the Developer evaluation of Installaware X13 and I testest the latest feature and its a amazing tool.
We are focusing to the APPX converter and we run into a problem during code signing.
Without code signing it works without problems. With code signing the coverter stops with error 110.
We use a Digicert certificate for code signing the MSI package and exe files without problems.
We would like to purchase the InstallAware X-13 Developer edition, but we need to clarify this problem.
At the moment we are using Installaware 18 and we would like to upgrade.
I hope you can help me.
Thank you in advance.
Kind regards,
Alexander Kotik
APPX code sign failure 101
Re: APPX code sign failure 101
Please check the full path to the certificate file you specified in the Authenticode settings of your project.
The MSIX/APPX builder returns such error code (110) when the certificate file cannot be found. Btw, this should be also reported with the log file stored within the output folder.
