Microsoft .NET 5 - Improved Detection
raggiesoft_dotcom
Post by raggiesoft_dotcom »
Synopsis
I was having difficulties with the included .NET 5.0.1 detection routine that is included with IA Developer X13, so I decided to create my own. The reason is the .NET 5 puts its version information in one of 2 places in the registry, and one of those key/value pairs sometimes contains incorrect data. My script attempts to overcome that.
This detects and installs .NET Desktop Runtime 5.0.4 (which includes .NET 5.0.4 Runtime), the latest bugfix release at the time I posted. These are meant to operate in your PREREQ section. This script is assumes you are running a hybrid x86/x64 installation that has already set the AMD64 variable as needed. Please feel free to use and edit as necessary. I hope it helps when migrating to .NET 5.
Requirements
* Your setup needs to make sure its running Windows 7 SP1 or later (this is a .NET 5 requirement enforced by Microsoft's installer)
* You will provide the .NET Desktop Runtime for both x86 and x64 systems, which you can download from the Microsoft website - or your setup can point to the .NET installer exe files that Microsoft hosts (https://dotnet.microsoft.com/download/dotnet/5.0)
Detection Script
~InstallAware Clipboard Data~
~End~
~{8A74C199-96D8-4E0C-841E-BE1C0E7DC100}~
~End~
~{8913EB19-1629-4EC8-84A7-7D1B34515783}~
~Set Variable~
~{26D54B0A-43A2-4BFC-BD1D-B69DF19CF218}~
~PRELIST$MYAH$MYAH$FALSE~
~$PRELIST$$NEWLINE$Microsoft .NET 5.0.4 (x64)~
~Comment~
~{D9245937-790A-49AB-84AA-4C675E83B374}~
~Check for .NET 5 x64~
~If~
~{79FE2E6B-3E05-446C-A058-7DEF34B1F83C}~
~SYSTEM_TYPE~
~0~
~AMD64~
~FALSE~
~Set Variable~
~{83C32791-9CCC-4912-AE6E-E74123C5A69B}~
~$PRELIST$$NEWLINE$Microsoft .NET 5.0.4 (x86)~
~Comment~
~{BD5904DA-E2A4-45AD-A8E8-A40DADAB3A3B}~
~Check for .NET 5 x86, even on 64-bit machines~
~Set Variable~
~{2BE7307C-4F74-4671-B066-834CD8246A6A}~
~INSTALL_DOTNET5$MYAH$MYAH$FALSE~
~TRUE~
~Set Variable~
~{0B793222-B8A3-4F33-950A-B6E5B6616A09}~
~PREREQ~
~TRUE~
~Comment~
~{8942DDFE-2B7F-40AE-80B7-CEE7D2799F9D}~
~Need to install .NET 5~
~Else~
~{E5DA73B8-6D1E-43BB-9587-4D80CA1B87E8}~
~GoTo Label~
~{F5043316-77EF-462D-BD6C-21BE1397BDB5}~
~IA Previous Version Check~
~Comment~
~{105F138D-794C-470E-A8CF-5FF6FE21FEE2}~
~.NET 5 is installed~
~If~
~{F8414D04-D515-4FFA-ABC9-FCFF77CE6185}~
~DOTNET5_VERSION~
~6~
~5.0.3~
~FALSE~
~End~
~{5FE3572A-F727-4212-8818-2756D7034480}~
~End~
~{31F2C89E-CF36-47CB-8A6A-D1B8A27171B5}~
~Read Registry~
~{8616DFD6-9386-4DD1-BE9A-1AAE73BA7493}~
~DOTNET5_VERSION|~
~2~
~SOFTWARE\WOW6432Node\dotnet\Setup\InstalledVersions\x86\sharedhost~
~Version~
~If~
~{81D23F5A-4621-4EFC-A1AF-6F346EFD37CC}~
~SYSTEM_TYPE~
~0~
~AMD64~
~FALSE~
~Read Registry~
~{424F0663-D65E-42A4-AF29-0622FD44002D}~
~DOTNET5_VERSION|~
~2~
~SOFTWARE\dotnet\Setup\InstalledVersions\x86\sharedhost~
~Version~
~If~
~{2534C500-61C7-466F-B7A7-FD3B8A38EB2D}~
~DOTNET5_VERSION~
~6~
~5.0.3~
~TRUE~
~End~
~{544CA7E9-940C-4FB7-B052-E41BD5AD4254}~
~Read Registry~
~{86DD452E-9E93-48A7-9D09-8DC0740D6F7F}~
~DOTNET5_VERSION|~
~2~
~SOFTWARE\WOW6432Node\dotnet\Setup\InstalledVersions\x86\hostfxr~
~Version~
~If~
~{870B94D5-F0D8-49D9-9B79-4D30DFB245B3}~
~SYSTEM_TYPE~
~0~
~AMD64~
~FALSE~
~Read Registry~
~{7D8591CB-131E-4377-B6DE-DDEA12DD7061}~
~DOTNET5_VERSION|~
~2~
~SOFTWARE\dotnet\Setup\InstalledVersions\x86\hostfxr~
~Version~
~Label~
~{A9053671-8ACB-43EC-B9AF-223651AFF859}~
~.NET 5 Check~
~Comment~
~{E6E1DF9B-CA7A-47A2-984D-5B17FAAA0BA2}~
~This is a lot more complicated than .NET Framework 4.8 or lower~
~Comment~
~{8CD31C53-5E6C-435F-8001-B509E0F88024}~
~Look for .NET 5 (There are two different places in the Registry)~
Installation Script
~End~
~{7EFA425C-1436-4F2D-BBED-62E3C2098843}~
~End~
~{78B7996E-805E-4161-A78F-AB1867D63429}~
~Set Variable~
~{15111C7D-2D5A-406A-959F-793000A2F427}~
~REBOOTCOMPUTER$MYAH$MYAH$FALSE~
~TRUE~
~If~
~{1C68807E-8EDD-4E15-A38D-E986F1FE7DE9}~
~DOTNET5_RETURN~
~0~
~3010~
~FALSE~
~End~
~{5AFBD025-223C-402C-A473-BF1D947201E9}~
~Set Variable~
~{BBC43B05-5270-429B-9BE8-161C3A3650E4}~
~TRUE~
~If~
~{22B626FD-BCCE-4023-9B58-F54212C99797}~
~DOTNET5_RETURN~
~0~
~23~
~FALSE~
~Comment~
~{896A612F-C439-4B1E-B12C-968588372992}~
~Request a Reboot at the end of Setup~
~End~
~{80488915-1651-4D3E-9E9F-E1F3C670C0AC}~
~Run Program As~
~{17254BC2-5C35-490E-9980-A0A4F16338F4}~
~$DOTNET5_X64$\dotnet5-x64.exe~
~/install /norestart /quiet~
~0~
~$MYAH_UACEX$~
~DOTNET5_RETURN~
~TRUE~
~File Bag~
~{A98933D0-08CA-4B1F-B0DC-D7D5FF59CC76}~
~"C:\Users\Micha\Dropbox\Tools\Setup Tools\Runtimes\dotnet5\dotnet5-x64.exe|",FALSE,DOTNET5_X64~
~mFileBagIDE.dll\mFileBagEXE.dll~
~Set Variable~
~{574B39DA-A4BC-42BB-BA0B-6F3D8B333357}~
~DOTNET5_X64$MYAH$MYAH$FALSE~
~Set Variable~
~{3CCCE49B-F842-425D-AB8E-20049B7FE6A1}~
~PROGRESSTEXT$MYAH$MYAH$FALSE~
~Installing Microsoft .NET Desktop Runtime 5.0.4 (x64)...~
~Set Variable~
~{A3C44165-42C9-46D5-BBAC-3A762E79B8A7}~
~PROGRESSMODE$MYAH$MYAH$FALSE~
~MARQUEE~
~Web Media Block~
~{AA019F92-8E08-49FA-BE46-E730C8FD2466}~
~Microsoft .NET 5 x64~
~https://raggiesoft.com/downloads/syscomp/dotnet/dot504-x64.7zip~
~FALSE$MYAH_CARET$~
~Comment~
~{2D07DA85-5192-4A0B-86E3-C84CC2F0E06E}~
~Install .NET 5 x64~
~If~
~{F7D2272D-0B99-4E28-BD43-0E22BDE7514B}~
~SYSTEM_TYPE~
~0~
~AMD64~
~FALSE~
~Run Program As~
~{634852A1-4C84-4070-885B-6426269E24C4}~
~$DOTNET5_X86$\dotnet5-x86.exe~
~0~
~$MYAH_UACEX$~
~DOTNET5_RETURN~
~TRUE~
~File Bag~
~{EA8F4830-439E-433E-BA28-CC6F560DE79A}~
~"C:\Users\Micha\Dropbox\Tools\Setup Tools\Runtimes\dotnet5\dotnet5-x64.exe|",FALSE,DOTNET5_X86~
~Set Variable~
~{33D11515-9BFD-4223-B44F-E231CF181E5C}~
~DOTNET5_X86$MYAH$MYAH$FALSE~
~Set Variable~
~{61981289-CDDF-483A-BA53-5486367357E1}~
~Installing Microsoft .NET Desktop Runtime 5.0.4 (x86)...~
~Set Variable~
~{01AB49B6-3A02-4791-AEEC-F815F17BB8B1}~
~MARQUEE~
~Web Media Block~
~{F5BF63B7-394E-4C20-8B42-A5B283407AAE}~
~Microsoft .NET 5 x86~
~https://raggiesoft.com/downloads/syscomp/dotnet/dot504-x86.7zip~
~FALSE$MYAH_CARET$~
~Comment~
~{C10E1063-220E-4ABC-B604-66D261606A37}~
~Install .NET 5 x86~
~If~
~{0AEF1B38-B6B5-4786-BEAA-67313F23C818}~
~INSTALL_DOTNET5~
~0~
~TRUE~
~FALSE~
~Comment~
~{887D1ADE-4191-41C5-B2CE-FB412C9A36D3}~
~Install .NET 5 as needed~
Re: Microsoft .NET 5 - Improved Detection
Thanks for posting.
However, it's not clear to me which kind of problem or difficulty you had with the IA .NET5 rtm included with IA.
Can you try to explain?
raggiesoft_dotcom
FrancescoT wrote:Thanks for posting.
Yes, absolutely. The existing detection routine in InstallAware specifically checks for .NET 5 Desktop Runtime 5.0.1, and does not account for any future releases (in the case of my development machine, I have .NET 5 Desktop Runtime 5.0.4).
My script checks the two places that Microsoft places the latest version of .NET 5, one of which sometimes contains old data, then adds the .NET Desktop installer to the PREREQ queue as necessary.
This is the PREREQ dialog of the dotNET Template on a machine that has .NET 5 Desktop 5.0.4, notice that it still wants to install .NET 5 Desktop 5.0.1
IA dotNET Error.png (17.86 KiB) Viewed 254912 times
Here is a screen capture of the Registry key that IA's script is looking for (note the lack of a 5.0.1 key, thus the IA script fails)
IA dotNET Error Registry.png (132.91 KiB) Viewed 254912 times
I just did a quick test, and in all honesty, I haven't been able to replicate any of the problems you reported.
Of course, our .NET detection routine specifically checks for "NET 5 Desktop Runtime 5.0.1". This cannot be otherwise. Due the fact that "currently", we exclusively support version 5.0.1 of .NET 5 Desktop Runtime.
But at any rate, this doesn't have any impact with successive versions of .NET 5 Desktop Runtime that could be eventually present on a target system.
I just tested our .NET detection routine on a system where "NET 5 Desktop Runtime 5.0.4" was already installed, and I didn't see any problem. Our check scripts successfully detected the presence of "NET 5 Desktop Runtime 5.0.4", and then skipped the installation of v.5.0.1 as expected.
Tinus
Post by Tinus »
Francesco,
I noticed the same issue. Try again in a system which does not have 5.0.1 installed but only 5.0.4 or later.
Then the IA script detects that 5.0.1 is missing although 5.0.4 is already installed.
Martin
Martin Rothschink
AxoNet Software GmbH
I just tried as you suggested, but I'm not able to replicate any issue.
I tried the following tests on a clean Win10 2004 x64 OS:
TEST 1
- manually installed .Net Desktop Runtime 5.0.4 x64
- manually installed .Net Desktop Runtime 5.0.5 x64
IA SCRIPT TEST RESULT
- v.5.0.5 x64 detected
TEST 2 - (.Net Desktop Runtime 5.0.5 x64 installed)
- manually installed .Net Desktop Runtime 5.0.4 x86
- manually installed .Net Desktop Runtime 5.0.5 x86
- v.5.0.5 x86 detected
TEST 3 - (.Net Desktop Runtime 5.0.5 x64 and x86 installed)
- manually uninstalled .Net Desktop Runtime 5.0.5 x86
- No x86 rtm detected
TEST 4 - (.Net Desktop Runtime 5.0.5 x64 installed)
- manually uninstalled .Net Desktop Runtime 5.0.5 x64
- No x64 rtm detected
Please let me know if you have more details to share about the test you did.
Tinus
Post by Tinus »
Sorry Francesco,
I was talking about ASP.Net Core 5.0.1 and 5.0.5. There the scripts only checks the registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ASP.NET Core\Shared Framework\v5.0\5.0.1\Version.
If only 5.0.5 is installed, the key is under
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ASP.NET Core\Shared Framework\v5.0\5.0.5\Version
and the check returns an empty Version.
Martin
Martin Rothschink
Martin, thanks for letting me know.
I'll check this out.
We released a fix to correct the problem discussed previously with the detection scripts of "ASP.Net Core 5.0.1" App Rtms, and as this has been reported by Martin Rothschink (Thanks!).
The problem affected exclusively the "ASP.Net Core 5.0.1" App Rtms, and not the ".Net Desktop Runtime 5.0.1" as reported by the user who started this thread. For what concerns this last one, as I have posted previously, I have done several verifications but I don't see the presence of a problem.
The "ASP.Net Core 5.0.1" App Rtms fix will be part of a next X13 update. In the meanwhile, and untill this new update will be not officially available, those users who have a valid X13 license may contact our support ([email protected]) for the fixed scripts.
Tinus
Post by Tinus »
Thanks Franceso for confirming the issue,
in the meantime I played with .Net 6.0 preview 3. This adds additional problems because the version is not a number (and the conversion in IA fails). Please download the latest preview and repeat your tests:
https://dotnet.microsoft.com/download/d ... 4-binaries
Martin
Martin Rothschink
Thanks for letting me know.
I did this test already and the fixed scripts don't present any problem with or without ".Net 6.0 preview 3".
Multiple versions of "ASP.Net Core" can coexist, and due of this, in our case it's just necessary to check if any of the version 5.x.x is already installed or not.
