Cannot cancel installation in french language
tosch
Post by tosch »
Weird problem here:
I have created a setup and translated everyting in german and french.
When I debug the setup in french and click on then 'Cancel' (in french) on the welcome dialog I can see that the WIZARD variable holds the value 'CANCEL'.
The line 'IF Variable WIZARD Equals CANCEL'.... the if statement evaluates to false.
What could be the problem here?
If I run the installation in German everything works fine. Also clicking on 'BACK' in french works fine.
Thomas
Re: Cannot cancel installation in french language
Dear Thomas,
it may be possible that translated strings don't reflect the latest changes you made to your scripts or dialogs.
I suggest you to re-import all your localized resources in your project ... including all Shared Strings.
tosch
Post by tosch »
You are right, there was a problem in the french translation file.
Thanks for your help.
Thomas
