Hello dear supporters,
my application uses a lot of nuget packages, which are to be found in a packages.config file in the
application folder, while developing.
How can I force Installaware to use these '.dll's dynamically to build an installer for my application?
Yours sincerly
Thomas
Nuget Packages
Re: Nuget Packages
Dear Thomas,
unfortunately there isn't a built in method which is capable to get the files to include from a config file.
However from the "install Files" command, it's always possible to specify a folder and to selectively specify which items have to be included at build time.
