Exclude files from uninstall
Quest3012
Post by Quest3012 »
Hi there,
During my installation I add database files (.mdf and .ldf) to the installation directory. I need these files to remain untouched when the program is uninstalled.
How can I achieve this without moving the files around?
Thanks in advance.
Re: Exclude files from uninstall
You may enable the "Permanent File" option with the Install Files command.
Quest3012
Post by Quest3012 »
This is exactly the solution I was looking for. Thank you so much!
