Dear Help
I have this error message : "Error during build: Unable to build setup files: Operation cancelled" Once I tried to build from external command via Jenkins or any other cmd software. I'm using InstallawareX13 admin version
Mor
Re: Error during build: Unable to build setup files: Operation cancelled
Dear Mor,
I don't think the problem depends on "miabuild" tool.
By the way, does the build complete successfully when invoking "miabuild.exe" from command line?
For example: miabuild.exe <projectfile>
Yes it's working from the CMD but to not from Jenkins
Injected runtime files
Compressing Album\21413AFD\7D4F914\CopyMaster.ini
Compressing Microsoft Visual C++ Runtime 14.0 update 1 (x64)\mFileBagIDE.dll\8CEEA2FA\VC_redist.x64.exe
Compressing Microsoft Windows Installer 3.1\mWinRun.dll\ansi\msiexec.exe
Compressing USTER® EVS FABRIQ SHADE\51E1C1A9\9D2BE839\Styles.Def
Compressing Microsoft Windows Installer 3.1\mWinRun.dll\ansi\instmsi.msi
Error during build: Unable to build setup files: Operation cancelled...
Any other option?
I still have this problem
The problem does not happen all the time, but many times during build it happens. I run the build again or twice and then it builds without a problemError during build: Unable to build setup files:
Build failed
As already said and for whar you are reporting, the problem doesn't depend on miabuild.exe.
It may be possible that when invoked via Jenkins, the tool fails to resolve system environment variable or project directories.
Then due the discontinuous behaviors, do you have any Third Party Anti Virus installed on your build machine?
Dear Francesco,
I can reprodcue the problem also from the installaware program and not only from external
To reprodce,:
1 press on build as one file (commpress to one msi file)
2. it's stuck with the error Unable to build setup files: during the compressing process
Compressing EVSNEWInstall.msi
Build failed
Process completed with exit code 1
28/10/2021 00:37:53: Step 'InstallAware complete build' failed
28/10/2021 00:37:53: Build ended (elapsed = 00:08:38).
3. It always happand during the compressing , any time it's stuck in a diffrent compressing level
4. Once I press to rebuild it (for one msi file like step 1) can solved the problem
What should I do to pass the compression in one time only ? What i'm doing wrong
Mor
To reprodce,:
Build failed
Mor
