Only one file out of two installs
JerzyK
Post by JerzyK »
Hello all,
I encountered strange behaviour when using Install File command. What I want to do is:
  • install Firebird,
    override two .conf files.
But what I get with code below is just
  • install Firebird,
    override only databases.conf file.
I run installer from InstallAware Studio (quite old version, InstallAware 2012 with runtimes, Build Moooya 9.26.11), or manually from Output Folder.
I tried to install them in different order, but it didn't change a thing.
I tested running those commands without installing Firebird (and having wrong .conf files in place), and it worked like a charm. Firebird installer is made with InnoSetup, but it's execution is supposed to be completed since InstallAware is ordered to wait until completion, so I don't expect problems from that side (maybe wrongly?).
I tried to delete those files in target directory after Firebird installation and before installing my versions, but again, it didn't change a thing.
I can manually override those files after agreeing to use Admin priviliges, which installer should already have.
I checked many times if firebird.conf I try to install is the right one - I copied path from IA project and opend the file - it's content is corrrect.
  if Variable FB_64_BIT Equals TRUE
   Set Variable PROGRESS to 70
   Run Program $SUPPORTDIR$\Firebird-4.0.0.2496-1-x64.exe $CMD_PARAMS$ (WAIT, get result into variable FIREBIRD_INSTALLATION_RESULT)
   if Variable FIREBIRD_INSTALLATION_RESULT not Equals 0
     MessageBox: Informacja, Instalacja Firebird nie powiodła się i zakończyła kodem $FIREBIRD_INSTALLATION_RESULT$.
     else
     Install Files C:\Projects\Product\install\IA\Firebird\Firebird_4_0_configi\databases.conf to $FB_TARGETDIR$
     Install Files C:\Projects\Product\install\IA\Firebird\Firebird_4_0_configi\firebird.conf to $FB_TARGETDIR$
   Set Variable PROGRESS to 90
I am puzzled what more can I try to overcome this issue.
I don't think trying to write a plug-in that would override those configs (or edit them) is the right call, since it might take some time and might still prove fruitless. But it is the only path I can see.
So all in all I am looking for your educated guesses what might be preventing my version of firebird.conf from being installed.
Re: Only one file out of two installs
You may try with deleting such files prior of installing your copies.
So for example:
else
	Delete Files \ (when installing)
(*) Set Variable NATIVE_ENGINE to TRUE, enables "IA Native Engine" and causes the immediate excution of the "Delete Files" command.
viewtopic.php?f=2&t=4338#p14960
viewtopic.php?f=2&t=11338
JerzyK
Post by JerzyK »
It worked like a charm!
Thank you, FrancescoT.
