we frequently use the Application Runtime Wizard.
How can self created runtimes be distinguished from installed ones on a developer machine, when all of these are located in the C:\Program Files (x86)\InstallAware X12\runtimes folder?
kind regards
Anja
Custom Application Runtimes
anja_laenge
Re: Custom Apüplication Runtimes
Unfortunately, the App Rtm Wizard doesn't provide the possibility to specify an alternative directory where to store the generated custom rtm packages.
you may move these manually to an alternative location once created. In such case, you also have to update any reference to such location manually in your custom scripts.
