Is there a way to save the output .exe (single self-installing exe) to a different directory depending on a compiler variable?
I want to build two different output files with a couple of different files to be installed depending on a compiler variable.
Thomas
Output to different directory
Re: Output to different directory
You may do something similar to what discussed here...I suppose.
viewtopic.php?f=2&t=8927
