I'm trying to uninstall installaware so I can install the licenced version.
Am getting windows cannot find myahew.exe. Also happens with modify.
Dave Craggs
Uninstall Installaware
Re: Uninstall Installaware
This sounds to be due a system corruption.
The only thing you can try, it's with running the setup.exe over the existing installation...this may probably fix the issue.
Finally got round to sorting this out.
I reckon the corruption was probably due to virus protection. MalwareBytes does seem to object to some Installaware files.
