Hi Team,
Hope you are doing well!
I am getting error to build .exe file "error during build : failed to compile plugin action : windows Installer". Can you please help me to resolve the issue.
Thank you.
Vijay kulkarni
Re: "error during build : failed to compile plugin action : windows Installer"
Your MSI script code is using the Windows Installer Plug-in, but this doesn't seem to be installed with your Installaware product. You should install such plugin to fix the issue. You may use the IA installer or from Add Remove Program (by selecting Modify Installation).
Vijay kulkarni
As i checked and confirmed that we are using the windows installer but still facing the same issue.
- image (1).png (63.78 KiB) Viewed 8913 times
This is the "Windows Installer RTM package" and not the "Windows Installer Plug-in".
https://www.installaware.com/mh52/deskt ... rhsyns=%20
From Choose Features installer, this is listed under the Plug-ins tree node.
Vijay kulkarni
We are observing this issue in windows server 2022. But we have the same installaware setup in windows server 2012 where we can able to create same build exe file without any error..
Vijay kulkarni
Can you please let me know what would be the solution.
Thank you..
Thank you..
FrancescoT wrote:This is the "Windows Installer RTM package" and not the "Windows Installer Plug-in".
