Disable uninstallation
mwilner
Post by mwilner »
I have two different projects that are based on a similar project initially.
One doesn't show the uninstall option in Control Panel\Programs\Programs and Features and the other does.
For these specific projects we don't want the uninstall option but I can't find any differences in the settings within IA.
Any hints of what I am missing and how I can fix this issue?
Thank you,
Manfred Wilner
Re: Disable uninstallation
I'm not quite sure to follow your question.
Do you want that your packages don't show the UnInstall option from Add Remove Program?
mwilner
Post by mwilner »
Hi Francesco,
Yes, I don't want to show the uninstall dialog and don't want the app to appear in the Control Panel -> Programs and Features or Add Remove Programs as you describe it.
Thank you,
Manfred Wilner
Dear Manfred,
please have a look at the following thread:
viewtopic.php?f=2&t=10517&p=39947
mwilner
Post by mwilner »
Thank you Francesco, this worked and you are once again a lifesaver. :D
Manfred Wilner
