I have been using InstallAware for over 7 years with much success. Every once in a while I get stumped. This is one of those times. I have tried every trick I know to remove the prior installation(s) and reinstall, but every time I run the installer I get a generic error message.
Below is the bottom of the log file. The problem originated when I installed a early beta of our product and removed it.
MSI (c) (C0:68) [22:34:06:555]: Creating MSIHANDLE (2277) of type 790531 for thread 18536
MSI (c) (C0:68) [22:34:06:557]: Closing MSIHANDLE (2277) of type 790531 for thread 18536
=== Logging stopped: 2/9/2022 22:34:06 ===
MSI (c) (C0:68) [22:34:06:562]: Creating MSIHANDLE (2278) of type 790531 for thread 18536
MSI (c) (C0:68) [22:34:06:564]: Closing MSIHANDLE (2278) of type 790531 for thread 18536
MSI (s) (F4:E8) [22:34:06:566]: Note: 1: 1708
MSI (s) (F4:E8) [22:34:06:568]: Note: 1: 2205 2: 3: Error
MSI (s) (F4:E8) [22:34:06:570]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1708
MSI (s) (F4:E8) [22:34:06:572]: Note: 1: 2205 2: 3: Error
MSI (s) (F4:E8) [22:34:06:580]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (F4:E8) [22:34:06:582]: Product: REDACTED PRODUCT NAME 9 -- Installation failed.
MSI (s) (F4:E8) [22:34:06:584]: Windows Installer installed the product. Product Name: REDACTED PRODUCT NAME 9. Product Version: 9.2.6.70. Product Language: 1033. Manufacturer: REDACTED PRODUCT NAME. Installation success or error status: 1603.
MSI (s) (F4:E8) [22:34:06:587]: Closing MSIHANDLE (5) of type 790542 for thread 19688
MSI (s) (F4:E8) [22:34:06:591]: Deferring clean up of packages/files, if any exist
MSI (s) (F4:E8) [22:34:06:593]: MainEngineThread is returning 1603
MSI (s) (F4:90) [22:34:06:598]: RESTART MANAGER: Session closed.
MSI (s) (F4:90) [22:34:06:600]: No System Restore sequence number for this installation.
MSI (s) (F4:90) [22:34:06:603]: User policy value 'DisableRollback' is 0
MSI (s) (F4:90) [22:34:06:605]: Machine policy value 'DisableRollback' is 0
MSI (s) (F4:90) [22:34:06:608]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F4:90) [22:34:06:610]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (c) (C0:68) [22:34:06:612]: Creating MSIHANDLE (2279) of type 790531 for thread 18536
MSI (c) (C0:68) [22:34:06:615]: Closing MSIHANDLE (2279) of type 790531 for thread 18536
MSI (s) (F4:90) [22:34:06:623]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (c) (C0:68) [22:34:06:632]: Creating MSIHANDLE (2280) of type 790531 for thread 18536
MSI (c) (C0:68) [22:34:06:639]: Closing MSIHANDLE (2280) of type 790531 for thread 18536
MSI (s) (F4:90) [22:34:06:641]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (F4:90) [22:34:06:644]: Destroying RemoteAPI object.
MSI (s) (F4:78) [22:34:06:645]: Custom Action Manager thread ending.
MSI (c) (C0:20) [22:34:06:649]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (C0:20) [22:34:06:652]: MainEngineThread is returning 1603
=== Verbose logging stopped: 2/9/2022 22:34:06 ===
Generic Error Message
Re: Generic Error Message
At the contrary, the error is clearly reported with your log:
https://www.installaware.com/forums/viewtopic.php?f=2&t=11358
https://www.installaware.com/forums/viewtopic.php?f=2&t=11442&p=43612
Users browsing this forum: No registered users and 43 guests
