MFC DLL ok in Call DLL function?
Fig
Postby Fig » Mon Aug 21, 2006 1:33 pm
Can I use an MFC dll (dynamically linked to MFC80.dll) in the Call DLL function of my script?
I am calling wbkey32.dll but always get FUNCTIONNOTFOUND returned. I have checked the exports of my .dll and the called function exists there. I have checked and re-checked the syntax and spelling within my IA script.
I also use this .dll within my deployed MFC app.
In pseudo-code:
CWbKey32App theApp;
// ... a bunch of MFC stuff, like MESSAGE_MAP, etc., left out here for brevity.
BOOL CWBKey32App::InstallKey2(
   long lVal1,   // input
   long lVerMajor,   // major version number
   long lVerMinor)   // minor version number
   // do some stuff...
   return TRUE;
extern "C" long WBInstallKey2(
   AFX_MANAGE_STATE(AfxGetStaticModuleState());
   BOOL bReturn = theApp.InstallKey2(lVal1, lVerMajor, lVerMinor);
   return ((bReturn) ? 0L : 1L); // return 0 on success
In the .def file
; WBKey32.def : Declares the module parameters for the DLL.
LIBRARY      "WBKey32"
EXPORTS
   WBInstallKey2 @1
Any help pointing me in the right direction would be appreciated.
... Fig
Postby MichaelNesmith » Mon Aug 21, 2006 3:43 pm
There might be name mangling involved. Please make sure you export your functions using this form (or similar):
extern "C" {
   __declspec(dllexport) int WINAPI
                FunctionName([parameters]);
Fig
Postby Fig » Mon Aug 21, 2006 4:40 pm
Thanks for the reply...
WINAPI is just short for _stdcall
I have already wrapped my exported function in 'extern "C"' specifically to prevent name mangling. Additionally, when I checked the exported symbols the function was named as I expected it to be (not mangled).
I did not pre-pend a _declspec identifier, but I *did* use a .def file and the function name is exported.
I suspect there is some name decoration that has gone awry, but as far as you know there are no MFC-specific limitations, right?
... Fig
Postby MichaelNesmith » Mon Aug 21, 2006 4:51 pm
Yes, AFAIK there are no MFC limitations - as long as name mangling, calling conventions aren't an issue...
Users browsing this forum: No registered users and 82 guests
