miabuild results
anja_laenge
miabuild results
Postby anja_laenge » Wed Feb 16, 2022 8:13 am
we are currently evaluating InstallAware capabilities in automated build processes.
the following was observed with X12:
Using
"C:\Program Files (x86)\InstallAware X12\miabuild.exe" "D:\_Projects\TheProject\TheProject.mpr" /b=1
the result is located at the usual "D:\_Projects\TheProject\Release\Single" folder BUT consists of a TheProject.exe and a data folder
Using
"C:\Program Files (x86)\InstallAware X12\miabuild.exe" "D:\_Projects\TheProject\TheProject.mpr" /b=1 /o="d:\single"
the result is located at "D:\single\Release\Single" and contains a single TheProjecxt.exe
Watching the output in the cmd window, I can see the compression taking place while executing the second version - not during the first. Is this an expected behaviour? The need to specify an output folder to activate compression?
Is there a way to get a single file result without specifying the output root folder?
kind regards
Anja
Re: miabuild results
Postby FrancescoT » Thu Feb 17, 2022 1:41 pm
Both parameters, "/b" and "/o", are optional and override default settings as defined with the project..
So just specify your settings with the project, and without passing those parameters from command line.
anja_laenge
Postby anja_laenge » Fri Feb 18, 2022 2:28 am
Hello Francesco,
I uninstalled and reinstalled X12 today and can no longer reproduce this behaviour. So maybe all was just due to some system quirk. No idea. Have a fine weekend.
kind regards
Anja
Postby FrancescoT » Tue Feb 22, 2022 9:15 am
Happy you solved.
Users browsing this forum: No registered users and 46 guests
