After installing X15, the splash and the version info correctly show X15.
The new License file sets them back to X14.
Freshly created License file reverts X15 to X14
Re: Freshly created License file reverts X15 to X14
I know that this might be a silly question, did you regenerate your personal license file?
pfennig
As stated in the topic header - even twice, once on Friday right after downloading the setup file, then again yesterday. The latter one was 3 bits larger, so I thought it would be the right one now, but it wasn't.
I even uninstalled and reinstalled the setup after each try.
Update: I gave it a third try. I once more downloaded the already existing file. It was exactly the same as the one generated yesterday. Then I regenerated the file and now I got a License file which is noticeable larger than the one from yesterday.
This means, the mistake wasn't on my side.
i'm very sorry for the inconvenience.
So the last one was the right one, correct?
