I am trying to add SQL Server 2014 runtime for installation in prerequisite but when I am building the project it is not creating the web media block file and I don't see any error. Any suggestion please.
Also, is custom 'SQL Server 2014 express with Advance feature' web media block file can be available to add?
Re: SQL Server 2014 runtime
Are you sure you selected to generate a "Compressed Web-Based EXE"?
https://www.installaware.com/mh52/deskt ... ttings.htm
Unfortunately we don't supply 'SQL Server 2014 express with Advance feature'.
At any rate, you can easily create your custom ones using the built-in "Application Runtime Wizard".
https://www.installaware.com/mh52/desktop/runtime.htm
