I'm trying to install 32.10 on our build vm. I'm using the single file installer because the web based installer kept failing during a module download. I went thru the initial dialogs, selected custom install and a subset of components, then when it starts the actual install an error message displays saying
the system cannot find the path specified
C:\Program Files (x86)\InstallAware X15\appv\ConvertToAppV.exe
Would you like to try again?
screen snip is attached.
Clicking yes gets the same error again. Clicking Yes to All appears to hang the install. Clicking No gets the same error message but with a different file mentioned.
I brought up an explorer window and it shows the path exists. The appv directory is empty.
Any pointers???
Getting System Cannot find the path specified error while running single file installer
- Install-InstallAwareX15-error.PNG (239.4 KiB) Viewed 6894 times
Re: Getting System Cannot find the path specified error while running single file installer
I suggest you to verify if your issue is due an installed third party Antivirus Application.
At such purpose, please verify the integrity of the downloaded package comparing the file checksum provided with our download page.
https://www.installaware.com/downloads- ... nloads.htm
Availability and description of the File Checksum Integrity Verifier utility:
https://support.microsoft.com/en-us/top ... b811e29559
Thanks for the pointers. We are checking the anti-virus on the VM.
