Moving from Trial version to Licensed version
seanmckenna
Post by seanmckenna »
Hello, when I first downloaded the trial I got the Studio Admin edition. Now I am thinking that we will purchase just the Studio edition. I assume I will need to uninstall studio admin and install studio.
My problem is, I have already developed a few setups over a few days, and I don't want to lose my work. Can I load my project, created in studio admin (trial), into the studio version?
Post by CandiceJones »
Hi Sean,
You bet! That will work out just fine.
ulrichard
Doesn't ask for the version to install after uninstall
Post by ulrichard »
Hi there,
I did exactly what was described above.
I tested using Studio Admin, and now purchased Studio.
As the unlocker program suggested, I uninstalled and reinstalled InstallAware. During the setup I was not asked which version to install. And afterwards, the unlocker again suggests to do a reinstall, because it found Studio Admin.
Ok, I did it a second time...still the same.
Good joke....
You're actually asked which version you want to install in the setup wizard. Please keep your posts professional or you'll be banned (this is your only warning).
