Freshly created License X15 does not work
AlejandroNehring
Post by AlejandroNehring »
I Installed InstallAware X15
I generated, downloaded and run the license installer
if "Run Installaware now" on the last screen of the licende installer is checked, InstallAware X15 runs.
On the next start InstallAware X15 tells:
"Thank you for Trying InstallAware" and wants me to buy a new license.
I repeated to generate and download and run the license installer. Same result.
I noticed, that the size of the license installer exe changes:
10.225.387 Bytes (generated on August 12th, 2022)
10.225.498 Bytes (generated on October 17th, 2022 09:22)
10.223.401 Bytes (generated on October 17th, 2022 09:32)
Re: Freshly created License X15 does not work
Do you have any Third Party AV installed?
Looks like an installed AV is corrupting your license file.
AlejandroNehring
no, it seems, as if only windows defender is active.
I deactivated windows defender, created a new license file, downloaded and run it .
Same result.
than I activated windows defender again.
Please contact: [email protected]
AlejandroNehring
Hello Francesco,
I contacted [email protected] on October 26th. Up to now no answer. Now I sent my again to the support
