The codesigning password is stored in any xxxx.mpr file unencrypted and this is getting into the source code repositoy. This is sub optimal. Is there a (simple) way to solve that security issue (miabuild parameter, compiler variable?
best regards
Wolfgang
Codesigning certifcate/password as a miabuild parameter or compilervarible
Wolfgang Guertl
BartWilson
Re: Codesigning certifcate/password as a miabuild parameter or compilervarible
I do this with InstallAware projects now as I noticed the same thing. Through Jenkins I grab the password from our Vault instance setting an environment variable (CERT_PASS) using the pipeline plugin withVault that is masked in our console logs. This is passed as a parameter to the miabuild.exe line as "CERT_PASS=%CERT_PASS%". In the password field in the project I put the "#CERT_PASS#" and that seemed to work for me.
Wolfgang Guertl
Yes this is working indeed, but die certificate password is dumped to the console/logfile.
Fix: miabuild ...... >nul
but all of the setup build process is suppressed. hard to find errors
Wolfgang
Wolfgang
BartWilson
I'm running my miabuild command line in a Jenkins pipeline pulling the cert password from a hashicorp vault using the "withVault" plugin, so Jenkins is masking the password for me. Not sure of other technologies and how they would possibly mask the password.
