Self Registering DLL - Dialog not closing since X15
Günther Schoch
Postby Günther Schoch » Tue May 16, 2023 12:53 pm
Hi
I switched from X14 to X15 and now the setup does close the installation dialog.
- turning off "file is self registering" -> works (but does not register the dll)
- turning on "file is self registering" -> blocks (BUT the DLL gets installed)
Looks as the main installer does not notice that the installation (REGSVR) process has finished.
REALLY an urgent problem. I recreated a minimal project from scratch. Exactly the same problem.
Does the "file is self registering" still works for others?
Re: Self Registering DLL - Dialog not closing since X15
Postby FrancescoT » Mon May 22, 2023 9:01 am
Can you please post a vary minimal sample project that replicates the issue?
Günther Schoch
Postby Günther Schoch » Sat Jun 03, 2023 3:59 am
as the case was really urgent, I implemented a workaround
    Set Variable REGSERVEDLL to "#TARGETDIR#\XXXComServer.dll"
    Run Program RegSvr32.exe $REGSERVEDLL$, startup in folder $TARGETDIR$ (WAIT)
BTW: Id I use the syntax with the parameter /s (silent), then I have the same problem as described. The install does block.
I assume, the setup cannot find the handle of the process properly and scans forever that "something" does close.
Users browsing this forum: No registered users and 86 guests
