Hi All
I'm trying to build with the checkbox Change Revision Code automatically upon rebuild - and the revision code not updated at all, stay the same number.
I tried to use the /r to miabuild.exe - nothing change
The only option is if I do it manually diretly from my installaware X13 UI and press on "Generate" button
There is any way to do via compilar verabile ? or any other way to do it ?
Thanks a lot
Mor
Re: Change Revision Code automatically
Please Check your Build Settings settings.
https://www.installaware.com/mh52/desktop/buildsettings.htm?rhsearch=Revision%20Code&rhsyns=%20
The 'miabuild' '/r' flag overrides the revision code generation specified with the project. However, this doesn't update the revision code value of the project.
Users browsing this forum: Google [Bot] and 60 guests
