Virustotal flags Installaware Setups as malicious!
Günther Schoch
Postby Günther Schoch » Sat Jul 29, 2023 4:50 am
It looks, as switching to Installaware 15 from an older version (pre 14) does trigger Virustotal security alerts for all setups produced via Installaware:
Test-Case1: Simple InstallawareTest project with one text file (attached). Just copy the 2 folders in the attached 7z file to c:\temp\ and build a Single Setup.exe. Then upload the resulting setup to virustotal.com. The result will show alerts and look like: https://www.virustotal.com/gui/file/c45 ... 4183b22a94
Test-Case2: Upload the newest Installaware Public Trial Setup (Web-Install) InstallAware_X15.exe. The result will show alerts and look like: https://www.virustotal.com/gui/file/422 ... 1c890020fe
Test-Case3: Compare with other installers e.g. a Microsoft Office Setup: https://www.virustotal.com/gui/file/0ac ... 2a0c18e371
= no alerts
Some of our customers do not accept our install! They demand that we have to fix the issue. But as Installaware is the supplier and has the same problem in their own setup, there is nothing we can do on our side beside switching the installer?!
What are the next steps? And as long other installers do not show these alerts, we cannot argue that the "Installer is OK and not a Trojan". The customers do just not accept with all the financial consequences for us!
pfennig
Re: Virustotal flags Installaware Setups as malicious!
Postby pfennig » Sat Jul 29, 2023 10:21 am
I can confirm this as an example for one of our setups with a size of about 450 MB.
Günther Schoch
Postby Günther Schoch » Mon Jul 31, 2023 3:29 am
@pfennig: Thank you for your verification. I assume allInstallAware customers do see that problem. Means as a summary "today we cannot deliver software setups to customer demanding to pass VirusTotal" (which is a rather common and logical request!).
Günther Schoch
Postby Günther Schoch » Tue Aug 01, 2023 2:40 am
@support: Any feedback on that topic that proofing to our customer that Installaware setups do not contain any trojan?
pfennig
Postby pfennig » Sun Aug 13, 2023 1:29 am
The web setup of InstallAware X16 is equally flagged as Trojan.
Postby FrancescoT » Fri Aug 25, 2023 9:05 am
What reported here is EXCLUSIVELY a FALSE POSITIVE, and about this, you may only contacy the AV vendor.
As a matter of policy we do not work around bugs in third party software.
Users browsing this forum: No registered users and 53 guests
