Remove pinned application from the task tray using IA x15 w/o uninstall script?
Coder For Food
Postby Coder For Food » Fri Oct 06, 2023 4:36 pm
I have a Win10/11 program pinned to the task try outside an install script. It was pinned manually. This means there is not an uninstall script I can run to remove the pinned app.
Is there a way to remove this pinned application from the task tray using IA x15?
Coder For Food
Re: Remove pinned application from the task tray using IA x15 w/o uninstall script?
Postby Coder For Food » Tue Oct 10, 2023 6:40 pm
Any movement on this? I am up against a looming deadline.
pfennig
Postby pfennig » Wed Oct 11, 2023 2:10 am
Pinned taskbar icons are Links stored in the hidden folder %AppData%\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar.
In your IA script you can use "Delete Files" to delete the link to your program. The option "Delete when Uninstalling" should be checked.
Users browsing this forum: No registered users and 106 guests
